I just received a Motorola T505 today actually.
I paid $45 dollars for it on ebay and it works great.
The speaker get REALLY loud and sounds nice and clear. It is a little tinny, but for the size of the speaker it sounds great.
The best part is the FM modulator that is in it. The Motorola T505 streams phone calls and music, Sprint tv (audio) directly to the car radio. Set up was simple turn it on, wait for it to connect to the phone, then push the FM button on the back and it tells you what channel to tune your radio in the car to. Thats it...done! Also, as long as there is something actually streaming to it from the phone it sounds really good on the car radio, but if it's just dead air, then there is some static.
I would highly recommend...
oh...you're looking at those types.....
I have the Jabra SP700. That and their Cruiser both get reviewed very well. I've been happy using the SP700 as a speakerphone. The Cruiser is supposed to be better with a dual mic so you sound better to the caller.
All of them (including the T505) are just ok when it comes to the FM transmitter. If you care more about music and less about the speaker phone (ie...not a lot of work/client oriented calls) I would seriously check out theKensington LiquidAux. You can do a wired audio connection to your head unit if you have an aux input or you can drop an extra $20 or so and pick up a wired FM modulator that plugs inline with the FM antenna and gives a way better signal with almost no interference compared to the cheap and not very powerful FM transmitters in the little speakerphone units. The Liquidaux comes with a wireless remote that clips to your steering wheel as well. Check out this thread at PreCentral for a lot of information on it. And there was also a thread started here too, but the PreCentral one is quite extensive.![]()
Oh.. More you show up /:
I'll give you the short version, turn off Wifi while listening to music over bluetooth.
The skipping is intermittent. Apparently not many people are having it.I'll try that. It wasn't skipping earlier today but I'm not sure if I had wifi on or not. Either way thanks for the info.
Hey guys,
Can anyone recommend a Bluetooth device (with a FM transmitter) so that I can
make/receive calls and stream Pandora through my car stereo speakers?
Is Motorokr t505 any good? Are there better alternatives to this? Under $100?
Thanks for any replies,
K
I wasn't able to figure it out. Somebody at XDA with a post count of 1 told me about it.
I can confirm from this morning that
1: it's intermittent. Ididn't skip until I turned on wifi notifications to test.
2: the only fix is to turn off wifi, notifications don't, or may not, have anything to do with it since turning it back off made no difference once it started skipping.
3: it's annoying
4: it's a bug somewhere
Another vote for the Motorola T505. I used it on a road trip this weekend, and it was awesome. Streamed Pandora and used Google Navigation and it went without a hitch. Paused Pandora when turns came up, and restarted. Great device, well worth it.
Hey guys,
K
Aubrey, I never tried playing music and using the navigation at the same time. Does it play the music and interrupt it when navigation says something?
I've had the motorola t501 (same as the t505) for a over a year and it always worked great with my blackberry. However I just paired it with my evo yesterday and all the music is skipping, including those songs played from pandora. I then paired the evo with a motorola s9 headset and it still skips, so I'm guessing it's the evo and not any of the devices. Is anybody else having this issue?
