Best case for note 2?
This thread made me want to try out some cases. I usually go for zagg type body shields but im not looking to put my phone away for 12 hours to dry lol.
I ordered the incipio LGND and if that doesn't work out then ill try the seidio surface. Ive had the surface for a prior phone and the lgnd for a tablet and i liked them both. If neither one does it im just going with a skin. Id go all natural but this phone is ridiculously slippery.
I got the seidio active case, had to sell my kidney for it since it cost me $58 even from Amazon but it's the best darn case i have seen. Very thin yet still provides 2 layers of protection. Plus it's got a nifty kick stand which i gotta admit does feel a wee bit flimsy but not flimsy enough to break off, just feels like it won't last 2 years. Otherwise amazing case, got it with the holster which is perfectly sized for a not too tight grip on the note 2 letting you easily pull it out and pop it back in yet it's secure enough that you could be doing gangnam style and your note 2 wouldn't even slip out a tiny bit from the holster.
Here is pics from my 8 dollar shipped case from ebay
1
Black Hybrid Hard TPU Case Cover Kickstand for Samsung Galaxy Note II 2 N7100 | eBay
The stand is CHEAP and does not go back in the case without a 2nd effort.
The volume buttons are a pain and do not make make it easy to use
The case material is halfway decent.
I would say if you are flat broke get this otherwise, its like a band aid till you can get a first class case. In face I am already shopping for a case with a stand right now.
Well the stand works fine now, took 30 to 4o clicks to break it in.
The volume buttons are next for me to get use to.
Thanks for this review/feedback, I crossed it out of my list. The rugged hybrid case I got off eBay (review in previous posts) working very good so far. I also ordered perforated hybrid hard case as an alternative (w/o kickstand), and was also looking at the one you pointed out (but not anymore). I will review perforated hybrid case as soon as I get it, which should be early next week.
This is a total fail, I went to work and the headphone plug area is too small for my headphone plug. This is going in the garbage.
Does the Defender have a big enough in the headphone slot for full size a full size headphone plug?
I believe it does.
When I was using the auxilary cable with my phone in the defender case, the cable had sort of a "fat head" so I had to use a little effort to push it in, but it fit.
Can't go wrong w otterbox. I purchased the commuter and it didn't add a lot of bulk to the phone at all. Screen protector doesn't interfere w touch at all. Very pleased overall
I tried this case but it leaves stitch marks in my invisi-shield screen protector, I got rid of it.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x649 and weights 62KB.
I want the Defender, just too steep price wise so this is what I have for now and will have to do.
Amazon.com: Bear Motion Premium Folio Case for Samsung Galaxy Note 2 Note II N7100 with Snap Button Closure (no magnet anywhere) - (Black): Cell Phones & Accessories
It does feels nicer than the price suggest, perhaps I should just stick with it and get my money's worth.
I tried this one and it puts stitching prints in my invisi-shield screen protector...I got rid of it...
I've had hundreds of cases over the years. The Otterbox Commuter I just received for my Note 2 is hands down the best I have ever had.
Can't you make the hole bigger/wider? Take a tip of a sharp pointy knife and scrape it in a circular motion. Of course you can use a dremel tool or drill as well ;)
Yes Sprint is the only store in my area that sold them and I went to every carrier store and three different Sprint stores before getting a commuter
For those who are on a budget and want Seidio *Surface* combo (sold from Seidio for $55), you can get it from Best Buy under their rebranded "Platinum Series" line for $35 - http://www.bestbuy.com/site/Platinu...uId=7175042&st=note 2&cp=1&lp=13#BVRRWidgetID
The only thing kind of strange was reading 2 comments on BB where someone mentioned holster being too tight to the point where it damaged screen protector and magnet holding kick stand was messing up the phone. But either way, you can always get it at the store and try it out.
Did i read that The Otterbox Commuter case fits really good in the Seidio Active holster. Has anyone tried?
I work with someone with the defender and it is huge. The Commuter is smaller but has no holster. What was Otterbox thinking.
I might try the Seidio Active combo on my belt. :rolleyes:
Totally love the Note 2 after having the Thunderbolt for two years
