Greetings!
This is only my second post to AF (I just joined today).
Primary Question: Does anyone know from experience if the OtterBox case for the
LG Optimus V is compatible with the holster for the LS700 (LG Optimus Slider), like the one
here from DeCoRo/VoiceComm.
I already bought the holster off Amazon, thinking that one of the entries in this thread had confirmed they were compatible. I re-read the thread again and found that one member, DBNissan, mentioned he had the OtterBox case on his Optimus and uses the "swivel holster/belt clip made for the Samsung M900," (
here) although he had to trim it a bit for optimum fit.
Some background: I like nice solid plastic belt-clip holsters like the ones that were supplied with the old Nextel i1000 iDEN phones. That was my first real cell-phone, although it was provided for work, and the clip never broke on me no matter how much I (unintentionally) abused it. This is what I compare most holsters to now.
I recently purchased the
Sprint holster/belt-clip for my phone, and it fits nicely, but only with the naked phone. I like this holster, and it seems sturdier than the one I initially purchased with my phone (from my local mall kiosk, around the corner from the Best Buy phone store).
The shell I already have is like this one
here, and the
first holster I bought is like this one
here. I don't know the manufacturer, but when my first one broke I was able to find it on eBay and purchased two so I would have a replacement if it broke. It seemed sturdy enough at first, but frankly the retention clip on top has a weakness: The spring-clip is nice, but the narrow bit of plastic holding the retention clip to the main body is thin, and breaks easily. The spring makes it possible to exert too much force and snap it off. In contrast, the Sprint belt-clip holster retention clip seems more sturdy because it is all plastic so it's less easy to break it unintentionally (so far, anyway).
I really like the belt-clip piece of the DeCoRo holster since it has a hook at the bottom for snagging on my belt. My main belt is a 5.11 brand leather belt with a polymer stiffener sandwiched between the two leather pieces. This belt is less compatible with the Sprint holster mentioned above: It makes the body of the holster (with the phone) angle out and away from my hip, making the whole assembly less secure. The Sprint holster is, however, very compatible with my hiking pants and a thin web belt.
Side Note: Has anyone successfully used the Sprint holster with any form of TPU or silicone skin on their phone?
Thanks in advance for any suggestions you can offer!
