Best charging dock?
I have that dock and like it a lot. I use it on my nightstand. Pretty handy I'll admit. I'm pretty sure it'll work with the flip case. Reason being is that I have the OEM Samsung hard case for my Note 2 which is thicker than the flip case. Samsung seems to have though out the designs for their accessories since the Note 2 with the OEM hard case, fits perfectly in that dock. So i'm quite positive the flip case shouldn't be an issue.
Just ordered the same dock based on reviews that said it was 2A and charged the battery in a few hours.
I just bought this one, which is actually for the Note. But a reviewer claims it fits their Note II (with a case; what case isn't mentioned), and it's only $17, so I figured I'd give it a go. All I need is a charging dock anyway.
It does say it'll sync over Kies, if that's of interest to anyone.
So I received my dock in the mail today. It does not come with a wall plug and/or usb cable. I guess I have to use the cable and wall plug that came with the Note 2. So I would like an additional wall plug and cable. Would like original product but don't want to pay $35. Anyone know of one similar to the original Samsung one? Must have 2A charge capabilities.
THANKS!!!!!!!!!!!!!!
