Thanks. Do I download it to my SD card then run it. There were no directions
Just did this on the 230 leak. Razrs Edge worked, but motofail failed(even though they appear to be the same).
do you have drivers installed? Did you make sure debugging is enabled?Razrs edge isn't seeing phone? I'm on leak .230
Any sugestions?
Ok, I updated the drivers but it still does nothing. just hangs at
adb devices
yep for debugging
How would I know if I have the latest drivers? I'm sure 4.0.4 has newer drivers.
