Help Best Flytouch locking application
Hi
Does anyone know of an app which provides a way to lock the Flytouch screen? I (very briefly) had a tablet with the ability to lock the screen and unlock it with a gesture. This feature is not available on my Flytouch, although I understand that this is because this functionality has been removed from the Android version I am running (2.2).
Therefore, if anyone knows of an app which provides similar functionality I would be grateful.
Thanks in advance
Well the widget I needed was "Pattern", not "Rotate".
Unfortunately this widget only works with Android versions up to 2.1. As mine is 2.2 it won't work.
Any other ideas please?
