Finding all the beer...huh??
Thanks for the feedback. I wouldn't have guessed to use a different wire. Was the 20 ga wire insulated or no?
What are y'all finding to be the best stable rom for battery life?
I'm getting frustrated watching my battery percent move faster than the minute hand.
Turned 4g off, screen brightness down, no live Wallpapers, wifi on when available.
If the screen is on for any significant amount of time, I can seriously watch the battery drain before my eyes running Viper. Otherwise I am loving this ROM. ver pretty and polished.
Is there a link to the viperrez ROM here? OR is it the ROM for the OneX?
Any of you try the CM9 Kang?
too much stuff not working to use for more than a couple hours. i have been following this thread to watch progress: [DEV ONLY] AOSP Development - xda-developersIf u read the neomax thread carefully, it has DLs for two alternate kernels, .7 and .10. You might try flashing .7 if u are still having heat issues.
i have,of coursetoo much stuff not working to use for more than a couple hours. i have been following this thread to watch progress: [DEV ONLY] AOSP Development - xda-developers
i figure theres not much point in flashing cm9 or milestone until they update the OP and buglists.
i personally cant wait for AOSP :smokingsomb:
Unfortunately I can't even get it to boot with either kernel. Just get the white screen with HTC.
Scotty claims .7 was just for gingerbread, so I'm not sure why neomax is offering it as an alternative kernel to run off of.
actually i think wat i said was the .7 kernel(along with the .10 and .12) are for sense 3.6. i dont recall saying it was for GB
the 4.0 roms will not work wit the 3.6 kernels
athiestrev,how are you flashing the kernels? and what rom were you using?
thats a good question. if viper is using the same kernel as the 3.6 roms,imnot sure how theyre doing it.So how does viperrez work with the .12 kernel? Is it because it also takes code from other devices? And senseless roms can use any of the kernels?
Btw u are right, u never said GB. I just got my sense versions mixed up. Sense 3.5 is GB, Sense 3.6 is ICS for non-flagship devices.
Not to make things more confusing, but I read where the htc one x is getting an ota that will take it to sense 4.1. One of the main diffs in 4.1 is it removes all 3D elements from htc widgets. Which if I understand is basically what the smooth rosie tweaks on many sense roms do, partly flatten or completely flatten 3D elements in sense. Would this be a case of OTAs imitating custom roms?? Lol
MODs:
Based on OTA 3.14.605.12 710RD
PNG Optimized APKs
Dialer by who MIKE D
Google Now
OC Kernel by SebastianFM
Transitional Animations by meXdroidMod Team & Stale Bread
Modified Default Sounds (Finally better ones to come)
Tweaked Build.Prop (Thanks Snuzzo)
Turbo Prop v2.0 - By: danutzz
HTC One Sounds
AdBlock (Hosts file)
1% Battery
Updated Graphics Drivers - Thanks Snuzzo
EXT2 Tweaks
Disable Debug Notification
Hardware GPU Acceleration
Custom Notification Icons Including Email & MMS
Customized Infinite Skin - Original by eboelzner
Customized Verizon Apps
Unlocked all Bookmarks
Custom Icons (Camera)
Includes Quickboot w/ Custom Icon
Includes Google+ Custom Blue Only
Custom Scripts Provided by NeWts
Kernel w/ init.d Support
