Root best kernel. and rom combo.
which combo will give me the best bench Mark dcore?
Hard to say but that's not an easy answer. Obviously you would have to overclock. Every phone is different though as I can't OC over 1.9 and others can.
What version are you on at the moment ?
I find any of ldriftas' ROMs work flawlessly on battery and performance , my phone has always loved ICK1.4 and homeless kernel , as the battery would last a day and a half with heavy use :) and a test score of 5124, but that's because I took anyway battery for speed and used pluage extreme kernel and OC to 2.2 it gets way to hot so I keep it at 1.2 now , I'm a battery saver kinda guy
Got a screen shot of this 5124? Would like to see your numbers.
One kernel I'll max out at 2.1. Another kernel I'll max out 2. But then I'll get one that reboots at 1.9.
I think it's more with the kernel than if you're phone can handle it. Only thing that makes sense.
