Well what if the EX stands for exceptional?My choice is Launcher Pro (as well as countless others). There's a reason why there is a Pro as part of the name.
LPP, doesn't lag (like adw) and I like the scrollable dock bar as well as the LPP widgets. Its all personal preference though.
I am another Go launcher user. Scrollable dock bar, supports scrollable widgets, light and fast with a bunch of swipe effects. I tried all of the free launchers for 2 days each and then went back to go launcher.
Just download all of them and set each one up about the same and then just tap the home button to jump from launcher to launcher and you decide which one is the best for you... Then let us know what you decide on ... Just out of curiosity
well comparing lpp vs regular adw is one thing...comparing it to ex is another
even on the best performance settings lpp doesnt scroll screens as fast as ex does...now that the lpp complete rewrite is well past a month over due....starting to loose a little bit of faith in fede...and lets face the lastest incremental lpp update just kinda ripped off ex with the the transition animations...and thats about it
I apologize for not being clear but I was referring to ADWex. I set up my primary home screen just as I have it on LPP and every time I tried to swipe from one screen to the next was no where near as smooth as on LPP (I'm using Beautiful Widgets 4x2, 4 icons and a 2x2 photo frame). It just seems, at least on my phone, that LPP handles more crap on the home seen a little better than EX did.
Go Launcher EX has a lot of the best of both ADW and LP...
