Best Mini Tablet? (3.5 inch or so)
I'm looking for the best mini tablet available out there whose screen can be read easily outdoors (aka anti glare :D). I don't need nor want a sim card slot or any type of telephony functionality.
I have seen the archos 32 which has decent reviews, but am looking for other suggestions. I will need these babies to run an independent android app that is not available in stores, so i need to be able to install the apk and run the android from these tablet.
thanks in advance!
Also I should clarify i need something pretty much the size of a smart phone, but in a tablet format (or basically, without any telephony features)
I am no expert in this, but you maybe better getting a PAYG phone, and not use the sim card at all? Where are you based (Uk/USA/Other?) You can get a good PAYG android phone in the UK the Sanfransciso on Orange for around
Hmm.......that's an interesting spin on it, thing is I live in a small desert village in the middle east and i need to buy a bunch of these things (like 20) so i don't think that would work.....unless i can find and dust off my fake ids........ :)
Not sure if that would be classified as a tablet if you're looking for something with a small screen. I've seen Android PDAs. Google it and find the one you like. But I agree, its probably better to get a paygo smart phone
