Root Best Non Sense ROM
VizualProphet
Hey guys was looking for some opinions on what you think is the best non sense ROM? I'm currently running LeeDroid 2.2f A2SD. I would like to shake things up a bit by switching to a non Sense based ROM, but I'm not keen on flashing custom radios and I would also require A2SD. Is there any cool ROMs that would fit the bill that you'd suggest?
Anything cyanogen based. Cyanogen itself is good, but I prefer defrost 6.1 (not 6.1a) but you may still have to flash a radio.
Its dead easy though. flash like a rom. Just don't power it off during the process.
@Completely hatstand - What's a baseband? Sorry I'm pretty new to all this. I did fancy giving Miui a go, would I need to flash a radio with that though? And also I wasn't aware it came with A2SD.
@Danfrance - I'd always heard flashing radios was pretty risky?
why not 6.1a????
I'm having loads of issues with the browser freezing at the moment on 6.1a and requiring battery pulls, thinking of changing to something else at the moment.
why not 6.1a????
Because apparently theres an LED issue with 6.1a, and 6.1 is the best version there has been to date.
I thought it was CDT 5.0 that stopped the LED working.....Dooh.
Looking at Cyanogen or even trying Sense HD
Lots of people complaining about leds with DeFrost 6.1a, but it works fine for me so it's not universal.
It's easy to switch ROMs, but it's also easy to give up on one quickly - you may regret the things it doesn't have before you appreciate the extra things it does have. Play with it, try to set it up for you, use it for a few hours, or preferably a few days, to make sure that what seems "worse" isn't really just different.
As for radios, the "HTC Desire stock radios" thread over in XDA is discussing a newer one, but there's no consensus on it yet, and as Dan says the one you have will be just fine (same one I'm using), so there's really no need to flash a different one (for DeFrost or MIUI).
I'd say try MIUI, and if you don't like the iOS style home, but like everything else, you could always download LauncherPro or something else ;)
Using lp on miui would go against the whole reason for getting the Rom
DeFroST is my favorite Froyo ROM, but if you want a Gingerbread ROM, I'd go with Oxygen.
