Best PSX emulator for PS1?????
Salution
I'm currently using FPSE. I have the bio's and games, my only problem is that the buttons for it on my LG is pretty huge. I don't know if it's suppose to be like that. I don't know if I can make it smaller, if it's possible please tell me how to do it. Anyway I need a good PS1 emulator without giant buttons, without the sound being staticy. So my question is simple, are there any emulators that are better then FPSE? Can I shrink the button size for FPSE?
Yeah u can resize the pads. The option is under video settings. Also try using SPU sync under audio settings. Its gonna slow your games down a little so I recommend overclocking. Turning off frame skip control also helps speed things up a little after spu sync. I hope this helps and enjoy cause you've got the absolute best psx emulator for any android.
Also remember to check the FPSE forums on the homesite for tutorials,tricks and new pads :)
