Does anyone have a recommendation for a good replacement battery for the LG Motion? Mine is only lasting a 1/2 day, when it always used to last more than a full day, as I don't use it a ton. I thought about an exented battery, but I don't really want to get a new case. There's a lot of battery choices out there, so I thought I'd check within the community to see if anyone had a good experience with one.
Thanks
Thanks
