Root Best Rom by far!?
Acid burns
Member
Look no bullshyt i need to know which rom is the best by far f@#k all that theme shyt which rom wont bug out it seems like every rom has a damn bug.When dealing metro there phones are not built tha same you can even see this with tha huawei ascend.Lets just be real which rom doesnt bug it seems like things happen to certain ppl with tha admire frum metro pcs.:mad:
Which rom doesn't bug you say? The one that came with your Admire is probably the one with the least bugs, but I'm not sure yet
If your phone can handle req's OC kernel then go after monster 5.3 full build along with paris's sexy ass ics theme if not go to the non ext4 build or go to P.U.T.U 2.2
no such thing as most 'best' rom. Do you like themes/throms, most stable, good/ better performance or?
Throms- Putu 2.2, Monster 5,4,3,1,Admiral Beast (som others too there are also themes to flash on these roms, such as paris's latest ics theme or monster.)
Most stable- Stock,(i'd pick boraichee's deodexed stock rom. stable, fast interface)Stock++,deodexed, ext4, themes, INIT.D AND LOCAL.RC.( some more..), yet again, admiral beast.
Performance wise - Stock++, tweak that shit. Overclock to 850mhz or 900mhz to see which is your phones sweet spot.
BETA Performance Roms. (Beta means there are still some bugs yet to be squashed - I.e fix for a camera or signal bar.)
CM7, Miui. Miui is cool but fees a little bit more buggy than cm7 ( i get some lags)
Cm7 - Has great amount of themes al over the internet/xda. If you dont mind broken GPS, Camera ( download fast burst camera for a temp fix.)
Try cm7.
So as a bugless rom.. Admira beast or stock deodexed.
Try them
I personally like Monster 5.3
There are some 'bugs' like the stock camera doesn't work well so I use UCAM and that camera is FREE.
I also use MX Player for my videos I play on my phone like Eminem "I'm not afraid" and such.
So if you want a basic no frills ROM then Admiral Beast would be the best choice because it has no bloatware and works great. If you want a little eye candy then Monster 5.3 non-ext4 edition is also great.
