Whats a kernel and how do I get it to work?
Which ROM has voltage control?In case you weren't aware, most of the ROM's have kernels where you can tweak the settings using Voltage Control and/or SetCPU. You can play around with the settings to get the best balance between performance and battery life...
Voltage Control has the advantage of being able to change the voltage setting (undervolt) and overclock, while SetCPU only let's you set the processor speed.
