xVermicide
Member
hey there, my mom just got an admire and i was wondering what the best rom is, or at least the most generally favored. thanks
before i do any rooting, should i upgrade to 2.3.6? she's on 2.3.4, just got the phone an hour ago.
thanks, i'm familiar with CWM. i myself have an LG esteem. thanks a lot i'm about to get startedwonferful question actually, use this to create a backup. trust me you are gonna want this and most likely need it if you intend on flashing roms.
http://androidforums.com/admire-all...-recovery-not-compatible-rom-manager-yet.html
once that is done you, id suggest performing a factory reset and then performing a backup through CWM. this will allow you to revert back from a rom or to get rid of your root incase you need it. as for the neew update, you can always try it and if you dont like then use can you previously stated backup to return back to 2.3.4. if you intend to have options like theming then dont update, the 2.3.4 has many more possibilities but thats just my view mate. oooh AND BY THE WAY WELCOME TO ADMIRE FORUMS!
so there are no 2.3.6 roms. got it. i only care about custom roms. that's what this thread was initially about lolUpgrading to 2.3.6 is a separate rom on it's own. So if you want it then upgrade but if you flash another rom it won't matter since it'll just erase 2.3.6. And there's no custom rom's based on it so i wouldn't do it unless you dont care about custom roms
yead definitelyi think that we can at least all agree that having an unrooted backup at your disposal is pretty much a necessity for Android phones
OMG just flashed it today OMG its sweet and smooth just one problem how do i get video to work???
Video doesnt work with the camera that comes with the rom. You need to uninstall it and install camera ics from the market that will fix the problem. As for the launcher, the launcher that comes with the rom is buggy and as you noted, does not show apps that are on the sd card. You can download a launcher that i know a lot of people like on here called "Holo Launcher". It is themed like ICS and looks really nice with the ics theme for this rom. If you dont want to do that however, you can just make backups of all your stuff on your phone with titanium backup and then everything will show up again. You will have todo this everytime you reboot so its just smart to get another launcherohh.. my.. god.. i really wish people would search before making post, just saying mate, this thread has been made a bunch of times already. 3 or 4 i think. anyways the most favored roms are OPEN ANDROID and MONSTER 5.3, they both have flashable ICS themes and they both have overclockable kernel versions and stock kernel version. remember not all phones can handle the overclock kernel as well as other so you yourself have to decide which is better on your device. DO NOT USE ROM MANAGER FROM THE APP STORE, you have been warned the most important crucial part of the admire . and the 2nd is to always read the threads, they could already have the answers to any problem you might be facing, and if you can find it then make a post within the appropriate thread and you will be help
Just outta curiosity, which is the "open android" rom? I searched the "all things root guide" and some other threads to try to find it. I'm happy with the rom I got, but just wanna check what else is out there. Might be missing out on something!
I guess I got thrown off too, cuz I was looking for a link different from the rom I already had stating "open android". I guess I've always thought of it as the 2.3.2 rom, since that's what it says in the link.--AND totally missed that the link says "OA"!!!! (stupidstupidstupid) LOL!
