guiitardude
What is the best, fastest, most stable, and best battery rom?!
these r my opinion. dont rage on me if im wrong lolAOKP and AOSP have alot of potential but unfortunately its not ready for daily use without camera yet. cm7 is ok but drains my battery. this goes for whyzors, TG and g60's rom. however ziggy's and mobstergunz's cm7 is looking pretty good it has hdmi working but still needs data fixed. Miui was great imo it had everything i could ever want but i cant help not having an android rom. minimal triumph is very fast and its more stable than most roms out there. so i think you should go with miui, minimal triumph, or cm7. cm9 isnt ready just yet
Froyo - b-rom (fastest ROM I've used so far, has all features working)
GB - CM7 g60
ICS - AOKP
I have nandroids of all three. If I need HDMI out, I'll restore b-rom. But my daily is CM7 g60, which I get great battery life from.
n everything is working too. i just dont like the color scheme
Im just really looking forward to camera for cm9, or even AOKP, then itll be my daily![]()
My daily is Minimal Triumph 1.0.8.1. I tried the GB version yesterday ans as soon as mms/sms works I'll probably switch.
I like MIUI v4 because of well its MIUI and its the newest one that we have. Even without camera its beast to me. Also even though it doesnt have as many themes as MIUI GB but its still awesome. I notice nobody said MIUI v4 why is that? It's my daily even without camera.
I just listed the ones I have installed and used. I haven't tried MIUI 4 yet. Figured I'll try it once cam is working.
Ah. You might like it better than CM9 might not trying to tell you what you gonna like just suggesting you know?
