In your opinion what is the best fully working ROM for our phone? I think Midnight seems to be the best. At least to me. The only other one that I tried was Mobster, but I didn't really like it for some reason.
every rom has it's advantages and disadvantages, some rom's are just more further developed then others, if you are looking for stability midnight, harmonia, mobster, meanrom are probably the most stable fully working roms out there, if your looking for newer updated software and consider taking a higher risk, CM10 is the way to go it has a beautiful UI and it runs super fast, it just is not 100% working or fully stable.
You have to add the S-on, S-off issues as well as the H-boot factors.
I've run ZR3DX, Mobster & Mobster Vanilla and Harmonia. They all run with S-on if you have 4EXT.
As big an issue is the kernel you use.
I've used stock, Mobs speed kernel (in both Mobs and Harmonia), and MAC kernel. Each kernel will affect the way the ROM performs and what you can tweak.
