Your s-on and have a over clocked kernel? How'd you do that? What h-boot are you on?I'm S-On and use MidNightRomS along with ButterToast Kernel and love it.
Make sure that the kernel is compatible with your hboot. After that it's pretty simple using fastboot, just extract the boot.img from the rom that you're installing, place it in your adb folder and run: fastboot flash boot boot.img.
OB
If I get s-off I don't have to do this tho right? Oh and thanks
No, if you have s-off you can just flash the rom with the included kernel or a separate kernel right from recovery. Some s-on users have reported success using 4EXT with smart flash enabled, can't vouch for that considering that I've s-offed all of my HTC phones. Definitely recommend 4EXT recovery though.
OB
I just need custom kernels so it'll feel like the good ol days with my og DROID
