I work at Best Buy Mobile and I would highly recommend the Invisishield Screen Protectors. They are guaranteed for life and scratch resistant. You can literally take a key to it and nothing happens. I've had one on all my phones and threw one on the second I picked up my Epic today. Just be sure to have one of our guys put it on for you because believe me these are like putting window tint on and you will screw it up if you try it yourself![]()
Naked...its the only way to go!
there's no padding on the plastic
But at least it will take the nicks and scratches away from the phone.
I got a pack of universal screen protectors from Radio Shack. They are WriteRight brand. Looks like crap when the screen is off, but you don't see it at all when the screen is on unless it's a very dark background (like the default messaging screen).
I'll use up the rest of the pack (5 for $8) before I buy something else.
) I work at Best Buy Mobile and I would highly recommend the Invisishield Screen Protectors. They are guaranteed for life and scratch resistant. You can literally take a key to it and nothing happens. I've had one on all my phones and threw one on the second I picked up my Epic today. Just be sure to have one of our guys put it on for you because believe me these are like putting window tint on and you will screw it up if you try it yourself![]()
