Root Best Setting for CM6
Ascend_45204
I just switched to CM6 and I will say i like it Alot But I was Wanting To know What Are the Best Settings for it To Save Batter I noticed the Batter is Draining Faster on CM6 then it did on CM7
for you battery go to setting and turn off GPS, that will eat your battery good...and far as setting, that depends on what you like and dislike, for example screen rotation, lock pattern, ect.....
