Help best users soft
rdev31
gues plz tell me ur best soft and also tell me the best task killer and how to acses wifi my laptop through my a 70 .....and best racing game
Use fast reboot and dont use other task killer it will consume more battery....what do u mean by wifi acess my laptop
This is my apps backup list ( the ones i always have installers and installed on my phone )
power amp
fruit ninja
uno Hd
taling tom 2
worms
x construction
moto x mayhem
launcher pro
call recorder
need for speed shift
assassin creed
tank hero
cam scanner
app 2 sd
advanced task killer
Ninjump
angry birds
advanced camera
YOU CAN ALWAYS HIT THE THANKS BUTTON , I WON'T MIND
power amp
fruit ninja
uno Hd
taling tom 2
worms
x construction
moto x mayhem
launcher pro
call recorder
assassin creed
tank hero
cam scanner
app 2 sd
Ninjump
angry birds
advanced camera
Hi CoolG,
can you tell me where does the apps installers get stored wen we download them from market?
I mean to ask from where you got installers?
we can get the installers using 91 PC Suite. in it in apps section,select the apps of which u want installer and right click on it and select save selected app and choose the folder to save and u r done.the saved content is its installer. i dont know from where cool.gautam gets d installer may b he also follows this way.
HIT THANKS IF HELPED!!!!!!!!!!!!!!!
the files will be in /data/app and /system/app folders... (if u have a file explorer, you can simply copy it from these folders)
I have just installed a app named root uninstaller ....just clik on app n den backupvu can even backup market installed or stock one's. even ;)
bade bhaiya market se easy wifi fix download karlo
it will fix any wifi related issues.
And my app list
neccesasary
1.APPS TO SD PRO
2.ROM MANAGER
3.ROOT EXPLORER
4.APPS BACKUP AND RESTORE
5.TASK PANEL(wont run in background thus wouldn't consume battery)
shouldtry
1.FRUITE SLICE
2.YOU NINJA
3.TALKING TOM CAT
4.ES FILE EXPLORER
5.DOLPHIN HD
5.MX VIDEO PLYER
6.GO LAUNCHER EX
7.GINGERBREAD KEYBORD
