Help best way to go from a Note 2 to a S4
Bobby_V
Hi All,
I have a Note 2 now and I am getting an S4 tomorrow (mainly for smaller size since I run a lot). I am a pro at switching phones but I usually just start over.
This time I want to see if I can just carry over what I have on my Note 2. How do you best recommend that I do that?
I have MyBackup Pro. Do I just backup using that and then when I get my device I install that first and the restore a backup? How anyone had issues with that?
I tried to search on the forums but something is up with Search.
Thanks for your help!
Bobby
I did the same change last week. I also used my backup pro. I found that as soon as I signed my google account name, it restored my apps from the play store automatically. I used the my backup restore feature to verify they were all there. It worked perfect.
