What is the best way to scroll web pages in the droid incredible? I use my finger to scroll (fast or slow).. and I keep accidentally clicking on links on the web page. I know I can use the optical track.. but not very fond of it for scrolling.
Anyone?
I have no problem using the screen to scroll. Try cutting back on the caffeine so you're less twitchy and less likely to click instead of slide?![]()
Dribbled coffee down my chin when I read that.I have no problem using the screen to scroll. Try cutting back on the caffeine so you're less twitchy and less likely to click instead of slide?![]()
BUT.....I always hit the back arrow to exit, but it just takes me one page back. That I havnt perfected and I HATE IT!
One day!![]()
That's what I use and if your having a problem with hitting the links and you want to scroll to top/bottom quickly, this is your best option in my opinionDolphin HD browser has the option to use the volume buttons to scroll up and down. That seemed to work pretty well but I prefer just using the screen.
really wish there was an easier way to "scoll to bottom" or "scroll to top"
