Roy Oxlade
Hi all
Well first battle seems to have been won, thanks to the help received here and I can now access my files that were hidden in the depths of the device. My next task is to be able to copy files from my Pc into the Android in the location that was hidden, but they only seem to be visible using the Android programs like Root Explorer and Solid explorer. So any suggestions on the best way to get files transfered, they are large files of several gigabyte? Is it actually possible in one transfer or will I need to move from Pc to SD card and then SD card to final location?
I will add that you can download from the supplier direct to the location and with a non rooted device so maybe a WiFi transfer from the Pc but how?
thanks Roy
thanks Roy
