devilschild26
Android Expert
That the whole reason there was web view issues I think it was ICS or jelly kernelAaaand there goes the lightbulb![]()
Well u can get ya self a warp sync and experience os M run any where from 40 to 60 bucks on Amazon plus boost is much better then virginI have been using this as a daily driver and it is very stable. Only real problems I have is battery life and no hardware video acceleration. The battery seems to drain fast and when I get to 17 to 15 percent it goes to zero in less than a minute. To bad there is no kernel mod for this and no gps. I have had lots of problems with the cm11 and + builds from Phenomx4. I know everyone has moved on to bigger better devices I just wanted to mainly say thanks for giving my device a stable cm11 even if it has the problems I mentioned I still wouldn’t run anything else as I feel this is the best rom for are phone. Thanks again.
I only pay 33 bucks for unlimited call text 5 gigs of data then slows down to 2g 8 bucks won't hurt uThe problems I mentioned above still arise, so I'm running LAwe, also daily driver, everything runs fine for me, and I get good battery life. Except GPS, I think that might be a hardware issue, its borked for me on multiple builds for multiple devices.
I'm still on the grandfathered $25 plan, so not yet an option![]()
Thanks for the kind words. Believe it or not I still come back to the ROM source every now and then trying to get GPS fixed. I can't tell if I'm close or not. I think it'll work if you run my "stock 4.4.2" ROM, get a GPS lock, and then switch to this ROM. Unfortunately I need to get the GPS HAL to build correctly first.
http://androidforums.com/threads/beta-4-4-2-stock-kitkat.952314/I have multiple devices and they even had problems with GPS out of the box, so I always expected it to be a hardware problem....
Does the GPS work in the Stock 4.4.2 build? I haven't tried that one, where is it? Its not in the All things root guide sticky...
It's a port from the Warp LTE, and also has a critical flaw. I never figured out how to disable the keystore and our radio image doesn't have the necessary files, so the Security menu crashes, no sideloading without a PC, and you can't uninstall apps
I only meant flashing 4.4.2 as a way to get 4.4.4 fully working. L-Awe is based on stock and shouldn't need any special treatment. The GPS software that came with the Awe is mediocre. I'm hoping if I get GPS worked out in 4.4.4 it'll be better.So, if I install this build and get a GPS lock then flash another build, the GPS should work reliably? Would that work with L-Awe? Seems counter-intuitive to me but I'm surely willing to try it, the GPS is awful on my phone, I only have the location service active, with GPS on it jams up apps when they try to get a lock...
