GUIDELINES FOR POSTING PROBLEMS:
IF YOU HAVE EVER HAD TO DO A BATTERY PULL ON YOUR DEVICE, YOU HAVE BAD BLOCKS ON YOUR NAND
BAD BLOCKS ON THE NAND ARE NOT FIXED BY A FORMAT. THESE BAD BLOCKS WILL CAUSE ALL SORTS OF ISSUES WITH THIS ROM
YOU WILL GET PANIC SOFT REBOOTS, FORCE CLOSES, AND A WHOLE HOST OF OTHER PROBLEMS, AND THESE PROBLEMS WILL BE MORE PRONOUNCED IN DEVICES THAT HAVE BEEN ABUSED OVER AND OVER AGAIN
(MOST OF THE ABOVE, IF NOT ALL, HAS BEEN REMEDIED)
WITH THAT BEING SAID, THE ROM HAS BEEN STABLE FOR TWO DAYS ON MY TEST DEVICE AND IS GOOD ENOUGH FOR A DAILY DRIVER IN MY EXPERIENCE--OTHERWISE I WOULD NOT GIVE IT TO YOU
THIS MEANS THAT I DON'T WANT TO HEAR ABOUT EVERY LITTLE PROBLEM YOU HAVE AND I'M NOT GOING TO WASTE MY TIME RESPONDING TO IT, AND NEITHER IS ANYONE ELSE.
!!!ONLY REPORT PROBLEMS THAT CAN NOT BE SOLVED BY THE FOLLOWING DIAGNOSTIC INSTRUCTIONS--THEN AND ONLY THEN REPORT THE PROBLEM!!!
1. ADW LAUNCHER IS UNSTABLE IN THE SMALL AMOUNT OF VIRTUAL MEMORY SPACE AVAILABLE AND WILL FORCE CLOSE AND HANG FROM TIME TO TIME. JUST COMPLETELY REBOOT THE PHONE TO FIX. ADW IS RESPONSIBLE FOR POWER OPTIONS REFUSING TO WORK AT TIMES, SO YOU MIGHT HAVE TO REBOOT BY ADB (preferred) OR JUST A BATTERY PULL IF THIS PROBLEM OCCURS
2. WHEN APPS FORCE CLOSE OR PRODUCE BUGGY BEHAVIOR, REBOOT THE PHONE COMPLETELY AND TRY AGAIN. IF THE PROBLEM PERSISTS, REBOOT AND WIPE DALVIK-CACHE, AND TRY AGAIN. IF THE PROBLEM STILL PERSISTS, REINSTALL AND TRY AGAIN.
3. THE PROBLEMS WITH BLUETOOTH AND WIFI, IF YOU EXPERIENCE ANY, I AM INTERESTED IN, BUT ONLY IF THEY ARE NOT FIXED BY REBOOTING, REBOOTING AND WIPING DALVIK-CACHE, OR REINSTALLING. ONLY THEN REPORT IT
4. THE CAMERA WILL TAKE PICTURES IN LANDSCAPE AND PORTRAIT, BUT IT WILL NOT FLIP THE FINAL PRODUCT. USE THE CAMERA IN LANDSCAPE MODE ELSE YOUR PICTURES WILL BE TURNED. DON'T REPORT IT CAUSE I ALREADY KNOW ABOUT IT. THE CAMERA WILL CAUSE THE SCREEN TO GET STUCK IN LANDSCAPE--SIMPLY LOCK AND UNLOCK THE SCREEN TO RETURN IT TO PORTRAIT MODE, OR JUST TURN OFF AUTO-ROTATION IN DISPLAY SETTINGS.
5. ALL OTHER PROBLEMS: FULLY REBOOT, TRY AGAIN. REBOOT, WIPE DALVIK-CACHE, TRY AGAIN. REBOOT AND REINSTALL, TRY AGAIN. DOESN'T FIX IT? REPORT IT.
6. REPORTING YOUR PROBLEM MEANS TELLING ME PLAINLY, CLEARLY, IN ACCURATE ENGLISH, BRIEFLY, EXACTLY WHAT HAPPENED AND WHAT YOU WERE DOING, EXACTLY, WHEN IT HAPPENED, AND WHETHER YOU CAN DUPLICATE THE PROBLEM EVERY TIME OR NOT. IF THESE GUIDELINES ARE NOT FOLLOWED YOU WILL BE IGNORED. POST YOUR ISSUE IN A RESPONSE HERE, DO NOT PM ME WITH YOUR ISSUES WITH THIS ROM CAUSE I WILL IGNORE YOU.
THANK YOU FOR YOUR COMPLIANCE AND HELP IN DEBUGGING THIS ROM
