DISCLAIMER: By using this kernel, you agree that you are the only one responsible for anything good or bad that may occur. Use at your own risk
For Boost Mobile ZTE Warp 4G N9510 only.
Let me know how it goes if anyone wants to test it
Current Features:
Overclocked to 1.56GHz (stock is 1.18GHz)
Underclocked to 162MHz (stock is 384MHz)
Default to stock frequencies
init.d support added
Insecure adb added
Wheatley governor added
Download:
warplte_442_OC_kernel_1-2.zip
Install:
Flash from custom recovery just like a rom. No need to wipe anything first. If you don't know how to flash a zip from recovery, you should not be using an OC kernel
For init.d:
In order to use init.d scripts, you must have /etc/init.d directory on your device.
You must also have busybox installed in /system/xbin.
You can flash this file to add the init.d directory, add busybox, and set the correct permissions
warplte_initd_flashable.zip
Note:
If you need an app to control your cpu settings, this one is nice and free Kernel Adiutor
Stock kernel:
Flash this to revert to stock kernel
warplte_stock_B12_kernel_flashable.zip
Current Features:
Insecure adb added
Download:
Install:
For init.d:
Note:
Stock kernel:
