So I was wondering about my battery life and would it make a difference on what charger I use? Jw bc the last two times I've used my gf Droid pro charger I got 12+ hrs easy off a charge.
Well, I would suspect that the only difference with the charger would be how fast it charges the battery. Charging from a computer, the USB flow is only 500ma, so it's going to take a lot longer than the HTC charger which is rated for 1A.
