Better cut not working with SetROM 4.5
I am running SetROM 4.5 on my HTC Desire.
If I load Bettercut, it says:
"unable to edit shortcuts for Android Home. If you are editing Open Home, you MUST install Open Home First. The easy solution is just uninstall Bettercut and then reinstall it (without uninstalling OpenHome)."
I have installed Openhome Lite, and followed those instructions with no avail :(
