Root Better Keyboard
Frihet
Has anyone tried Better Keyboard 7? NooKDev says it should work, but, alas, it does not. It appears to install (files are in /data/app), but does not appear in the keyboard list so it can be selected.
I would really like to have a Swedish keyboard, but neither SwiftKey or Better Keyboard seem to work -- for the same reason. No way to select them after installation.
Note: the keyboard selection page implies the keyboard needs to be installed into /system/app, but I don't see how to do that.
To get an .apk into /system/app you either need to use adb, or use a file explorer program that has root access, like ES with root and R/W enabled (read/write)
Using file explorer (ES) go into settings and enable root, and enable R/W. Now find the apk you downloaded and copy it. Then navigate to system/app, and paste it. Then reboot.
