DesireMe
Android Expert
OK, i like the HTC contacts widget, but i'd like it to be horizontal instead of taking up the a half of a page.
Is there a similar widget that can be shown horizontal?
If not, is there a widget/app to help with this......
I have quickdial shortcuts on the home screen, but as it's only a call or message, i find i've got a couple duplicated.
What i'd like is the same picture shortcut, but if you press or hold it, then a slide-off or drop-down will show to select action, be it call, sms, email etc. (With the bonus of setting the default action).
Does anyone know of a solution to this?
