MelonSplitter
Member
I have been using Handbrake for a while and really like the ease of use. However, I have a serious problem with the LOW audio output. Is there another program that has better audio output than the "brake" ?
You can adjust the audio volume. When you are in the settings click the audio and highlight the stream. Increase the volume in the drop down box to 4. Make sure the resulting output also shows 4 (sometimes it doesn't and you just do it again).I have been using Handbrake for a while and really like the ease of use. However, I have a serious problem with the LOW audio output. Is there another program that has better audio output than the "brake" ?
i just got my EVO a week ago, and ive never used handbrake before. whats the best settings for my EVO and what is a good site to download good quality movies?
I only use Daniusoft Video Converter Ultimate, it's integrated with full function of DVD Ripper, Video Converter, DRM Removal, DVD Creator, Youtube Downloader, etc and the latest version support 5X faster video conversion on any computer with a CUDA-enabled graphics card. that's really great, you also can check more info via this review: Handbrake VS Daniusoft Video Converter Ultimate
I have not used handbrake for a while though. I used Xmedia Recode for all my video conversion needs. I think its the best. Try that program as you can normalize your volume and also change the volume settings from 25% to 125%.
If you want to try that program let me know here or through messaging and I will send you the HTC EVO profile I made. All you need to do is add and hit encode for your video.
