Why?The only difference is that it would charge faster if off because it won't also be using any power. It doesn't make the battery perform any better or worse.
The downside is that you won't get any calls with the power off. Turning a phone off to charge isn't something I would do.
Why?
AT&T pushes out very small yet important network updates regularly as they improve the network. Your phone must be off to trigger the transmission of updates to it, the next time it's turned on.
Can't those updates be triggered via "check for updates" in the about phone menu?
Why? AT&T pushes out very small yet important network updates regularly as they improve the network. Your phone must be off to trigger the transmission of updates to it, the next time it's turned on
In an attempt to get better battery life, I am going to try charging the phone while powered off... we shall see how it does.
Scott
att pushes small updates??? hahaha okEither on or off is fine.
However it's _very important to turn your phone off at least every other day. If your practice is to leave it off while charging that will do it.
If however you never turn it off, it's important to change that habit.
As long as you turn it off and leave it off for just two short minutes. That will be enough.
Why? AT&T pushes out very small yet important network updates regularly as they improve the network. Your phone must be off to trigger the transmission of updates to it, the next time it's turned on.
Cheers![]()
I always had a theory with computers that people who constantly shut down and powered up their computer everyday instead of hibernating, had overall shorter life in them or more complications.. Anyone heard of this?
I had a problem with my Samsung captivate. It wasn't receiving any text messages. Called AT&T turns out it was because I never turned the phone off and missed a network update. They suggested that the phone be turned off for just a few minutes every couple of days. Now I try to do that with my Inspire so I don't run into any issues.
Definitely not urban legend!!
