Root big mistake
cornelljdavis
i tried to flash stock root from apache thunder but did full stock on accident. i redid all the steps for the unlocking and rooting my phone but i cant install the cwm because my hboot is now the 1.300 whatever version. so when trying to flash the stock root it to the 1.0 hboot one i cant becauseo old and you have to flash that in cwm before you can the down the grade hboot. i will keep trying but if anyone can help i will appreciate it
I don't know how to turn off the version checks but all I do to get around version too old error is open the rom zip and open "android-info.txt" and edit the "mainver:" line to a number higher then my current one. Not sure if this is the right thing to do but it works.
