Root Big problems with market on xtrRom
PiperCub49
Member
Hello,
I've been using xtrRom 4.6.5 for quite a while now and it has worked fine up until this point. Now I cannot download or upgrade anything from the market. It says that the files are downloading, but they never actually do. I've left my phone overnight and nothing changes. I've tried going to the 2.2 market and back again, toggling 3G and wifi on and off, and rebooting, and still apps won't download.
Does anyone know what's going on or how to fix it?
Thanks,
PC49:)
Try clearing the data and cache on the Market app
Menu > settings > applications > manage applications.
Let the list load, scroll down and select Market. Clear Cache and Clear Data.
One thing to try is to start and make sure that you are logged in to Talk. I seem to recall that sometimes that fixes things. If that doesn't work, perhaps changing your Google account password on a PC, waiting for Android to give a notification to change the password, and see if that works better.
