Can I add bigger memory card to boost mobile samsung galaxy s2. Factory specs is 32gb max. Want to do 64 or 128. Is it possible? If so how difficult is this?
You may well find that the phone simply won't recognise the larger capacity cards or won't read/write from/to them reliably. Not sure there's much you can do about that ..
I have a vague memory that the 'regular' SD standard only goes up to 32GB and that 64GB and larger use an enhanced standard (I could well be wrong about that) which might mean your phone not working with the cards at all.
If you can get a larger capacity card from a reputable company that accepts returns, you could just suck it and see, of course
