Phone is awesome; got the GPS dock and it works great however the map orientation isn't correct. It seems to always be in the north-south and instead of showing you streets coming up to where you are located it is upside down, or worse shows you going left instead of right.
I've looked everywhere on the phone and haven't been able to find a setting to orientate the map in the direction of travel (like a normal gps)
Perhaps it does this in navigation mode? Going to try that out in a bit.
Any help or thoughts would be great
Thanks!!
Thanks!!
