Bionic has a scratch on the screen, help..
ncdude
Hi everyone,
I noticed a small lite scratch on the screen down by the touch buttons, not sure how it got there. I went to verizon to talk to them about it and they were less than helpful. So my question is, is there a way to buff out something like this? It is very light and goes away when you wipe the screen off, but when you use it the finger prints make it visible. Bugs the hell out of me.
Thanks,
Scott
Hi everyone,
Thanks,
Scott
You might be able to use some type of glass scratch filler. But a screen protector will usually hide any minor scratches as well.
Yes, please invest in a screen protector. I like the static cling ones. Look and stay on great. I misplaced my current one so i order another for 99 cents off ebay with free shipping. Please get a good case too to prevent damage :) good luck!!!
+1 to cheap screen protectors from ebay! I have had them on my devices since who knows when and they hold up very well for only a buck. Plus if you can get multiple (I won a 10-pack for $.28 w/ free shipping for my TB) then you're pretty much set for the life of the phone. Easy on, easy off when you want to.
It will also hide minor scratches as mentioned, so this is probably your best bet. Make sure it comes from a state close to you though if you want one ASAP, otherwise China does take a couple weeks.
When I got my OG Droid within the first week I somehow managed to put a scratch on the screen. It's still there to this day and did bug me a bit but I ignored it. Right away as soon as I got my Bionic I bought the screen protector. I will hopefully no longer have to stare at a scratch again.
