Bionic SD Card size
Yes, it will work. I just formatted it in the Bionic. When you put the sd card in you'll get an error, just ignore that and go to settings/storage and scroll down to external storage and tap on erase. That will use androids own OS to format the new sd card.
I didn't even know 64 GB micros existed! I probably can't afford one but it's good to know they exist.
