Coronach
OK, so I'm having an issue with the native USB Tether on my Droid Bionic. It works great with Linux and Win7. It's a non-starter with XP. So, I went to help, and I saw that you need to DL the tetherxp setup file. I also did a little searching and saw that SP2 and earlier versions of XP will have some more difficulty. So, I checked the versions on my wife's computers- both SP3. Excellent, I shouldn't have to DL the RNDIS drivers.
So, I proceed with the instructions, and I get ... nothing. The wizard says that it can't locate the drivers, and that my device may not work properly. Lo! and behold, it doesn't work.
So, right now I'mDLing the RNDIS files to see f that is the issue, but I don't want to screw with the OS unless I have to, especially since what I've read says that if XP is SP3 or higher I shouldn't need them. Is there another angle I can try?
Also, is the tetherxp file supposed to be really small? It's only a couple of K.
Thanks,
Mike
Thanks,
Mike
