Root Bionx (Project Closed)
It's an eventual goal. Not necessarily going to happen soon but biotic and I are collaborating on a custom kernel for this rom and we have discussed plans for a bluetooth fix.
Indeed
Our focus is speed and smoothness than concentrate on bugs. Essentially a kernel source that could be used for anyone who wants to take a shot at a stock based rom.
Very close
Sent from my Xperia U running Miui using Tapatalk 2
App is pretty much stable. Right now is the rom. Xperia launcher wont install for some reason
Sent from my Xperia U with Miui
Wish I had a good internet provider right now cuz aosp source would be so helpful right bout now o. O
Converting stock to aosp is a freakn "B" with LG but im slowly jugging away. Android settings arnt cooperating at all -. - as far as the Bionx Dashboard, fully functional for what i have done. So much easier on the Razr... Lol
Well, I got the kernel to build. I haven't had a chance to test it quite yet though. I'll try and get that done by Sunday night. If it boots, I'll let you know.
Center clock on statusbar? (yes or no)
Delete LG settings in android settings? "Screen settings, powersaver, ect" (yes or no)
Clean pull down bar or leave toggles? (opinion)
Your opinion matters.
Yes to center clock.
I don't really care about lg settings.
Personally, I like the toggles in status bar. Although, a clean look could be nice also.
Also, just put together a boot.img of the same kernel, I would like to see if it will boot this way. Will pm you a link in a bit.
Hmmm maybe a swap script is in store... Il clean the the system UI up than try putten together a script to allow u to swap.
Thanks for the feedback guys
Edit: System ui keeps force closing so il need to rebuild some things. Might come later in the build.
I have a beta build up. Whether or not it installs correctly is unconfirmed yet so do a nandroid before install.
Link to Bionx forums is in first post.
If it the beta install correctly, can someone rehost for me please.
Soon as I have access to wifi, I'll check it out.
well i had it rough
flashed the rom and it worked but it was stuck at
"updating partition drive" or something and i was using twrp
and it was there for like 10min so i held the power button and rebooted
then it got stuck at the twrp screen just said teamwin and bootlooped into that screen and couldnt get into to recovery, so i just used the cab method to flash back to zv7, so now im going to use CWM instead and see how that goes, btw thanks for the rom!
well i had it rough
He had informed me it was a bad upload, it will be re-uploaded tomorrow. I'm on cwm and all it does is install fast and get stuck at "LG" .
