likenokevin
What finally worked for me was the sync now command inside the contacts menu.
Probably a dumb question... But how do I import my contacts from Google with this rom?
wow....Phillip tell us what you really think and just flat out accuse him of stealing nitros work! really? so because one thing is similar between roms you can automatically draw a correlation between the 2? first off I don't think he would do that, and second if it was based off eclipse why wouldn't he specify that? it just seems like kinda serious statements to be throwing around.
Altho i dont have an active spectrum, i do see where your coming from.
Il see what I can do. If these hickups continue just one after another, i might just start over on a jellybean base.
I ran a log and debugger last night while i had my Spectrum just do random processes, about 20 errors and force closes were noted. I gotta track every one down 0.o
Just started on next update. Looking good so far.
Sounds awesome.
The not so awesome part is I have to manually add everything lol (Powermenu for example)
Okey, main goal right now is rebuilding AOSP. Im currently trying to get power menu working correctly (Nothing fancy) and produce a nexus like build. Basically using TDMs build as a base but rebuilding as much as possible from source and enhancing the android environment.
I might release the base as a beefed up Aosp build but whp knows.
So, all in a nut shell. Be patient on this build. Alot of work todo on my end.
Btw, whats the spectrums screen size? I wanna make some splash images.
I believe it's 1280x720. It's 720p resolution so if all else fails, you can google what it is.
