Help Bit of a restart issue
xxartixx
Hey guys,
Not sure how long i've had my note now, and its been fine, great little-big phone but recently the past few weeks it keeps restarting itself randomly. Could this be something i have downloaded? Does anyone elses note do this? Also does anybody have any tips for me? I always get android phones but never seem to use them to their full potential? My screens always a mess and my phone book is ridiculously large due to the fact i have duplicate names for fb and phone numbers
Yes, I have had this problem once or twice, but not to the point that it has started to annoy me. There have also been a number of posts on this forum on this topic. You are certainly not alone.
Nobody has found the cause of the problem so far but I guess that the frequency of the reboots could be due to the mix of applications you are using. I cannot tell you more though. My advice would be: if the reboots are few and far between then just ignore them. If not, you could try testing different applications and see which appear to crash the phone the most.
I wish you luck with your search...
Regards,
Eric Ritchie.
Yeah, mine has started doing that as well. It only happens once every few days or so, so it's not a big deal, and it only takes a minute to reboot.
