Root bit of help needed
dave1977
hi i have 2.2.1 CM HACKDROID v0.12 rom installed and i was just wondering if anyone new how to set my ring tone to one iv got of my own cheers:confused:
once again you've solved the most complex problem of android... you should get employed in the google office man..
Yes, I keep telling them that. And it was a difficult one.
Dave, did you notice the ringtones folder in your SD card? Put your audio ringtone files there. (using a file explorer / file manager)
