blank sd card
  • Start date Start date
Welcome to Android Forums.
If you wiped your SD card by mistake, then the data on it is lost. If you did not backup the data on the SD card to your computer then your data is really gone.
If this is not what you really are talking about, please refer back to the forum specifically for your device in the main forum menu.
