Root blinking lg at boot up
lg vortex rooted ok so i rooted with superclick but struggled to find a custom restall and somehow got it im assuming in bootloop. it just keeps blinking lg over and over. Then thru some multi button senerio i got it to go to a screen that said verizon updating don't unplug but it just stayed their as well please help
Welcome to the Android Forums, bighead7391!:)
I see that it has been a few weeks since you posted this and still no replies, so I have moved this thread into the 'all things root' section of this forum since this involves rooting, in hopes that you will get some help here.
Hello! I appologize for not being on too help you but, if you are truely bootlooped there is a VERY helpful tool that can help you. When you got to the screen that said "LG IS UPDATING DO NOT UNPLUG" That is actually part of the tool. So first of all, what I am going to tell you, I have had to do twice, and it will revert you back too stock. I may be able to help you root it later on. The thread for the tool called "LGNPST" (Yes there is on on the Android forums but, I used this one when I bricked mine so i trust it) is right here: How to downgrade LG Vortex - xda-developers
EDIT:
Just follow the instructions there, and you should be good.
