I was able to remove pretty much all metro apps with no problem
metro easy wifi
metro 411
metro appsttore
my metro(since I dont pay for my phone from the app)
m studio
total protection
those are the ones I was able to remove I also want to remove the google apps but im afraid it might brick my device. hope this helps!!![]()
how can I extract it
Once its on your SD Card, plug your phone into your computer, put the app folder on your Desktop or something, put it in a zip file and upload the zip file to Dropbox, 4Shared, 2Shared, or some other file host.
will that file have all of the stock apps and odexs?(just in case)lol.or has it already been modified.?..ive already removed all the same apps..(in case i ever have a warranty claim).thanks
