Hi
I wonder if it is possible to block android updates via 3G and leave it alone for wifi, I have not seen this option to enable, in a galaxy instead note2, if you can select one or the other, how can the nexus?
This morning I have downloaded via 3g and have used some 74MB, my bonus is limited data, is there option then prevent the download if you're not on a wifi network?
En google play tengo marcado que se actualice bajo wifi, pero no parece que funcione sobre las actualizaciones del sistema
thanks
thanks
