Help Blown ear speaker?
Anyone have this problem with the EVo yet? Pretty sure mine is busted.
I think mine has the same issue as well since the wife's Evo seems perfectly fine. Tried to simulate/replicate the issue by playing the automated voicemail received from google voice. Mine has the "vibrating/rattling" sound... also kinda like the sound you hear from really small speakers when volume is set on high.
I put my name on the waiting list so I can have it replaced. Just a little bit scared since the Evo I have now is good except for the ear speaker...
If everything else is good on it and you think you can live with the ear piece issue then I would. I had a 7-8-10 build evo that had a distorted sounding ear piece and everything else was fine on it. It all went downhill when I exchanged unfortunately. In hindsight, I should've kept that one and been happy with it.
